Optimization and Control of Nonsmooth and Complementarity-Based Systems: Theory and Numerics
Organizers:
Gerd Wachsmuth (TU Chemnitz, Germany) and Thomas Surowiec (HU
Berlin, Germany)
Abstract:
Given the rising amount of phenomena in telecommunications, economics, image processing, and engineering that can be modeled as complementarity or equilibrium problems, i.e., (quasi)- variational inequalities, both the theoretical study and numerical
treatment are of major in- terest. In all of these models, one is provided with several
external parameters. The wish to achieve a desired state or to calibrate these parameters according to observations, then leads to optimization problems with complementarity constraints (MPCCs, MPECs), nonsmooth inverse problems, and hierarchical or
bilevel optimization problems. Due to a general lack of regularity of the parameter-to-
state mappings or the inherent degeneracy with regards to constraint qualifications of
complementarity constraints, standard methods of nonlinear programming, optimization in Banach spaces, and optimal control cannot be directly applied to analyze these
models or develop ecient numerical methods. Further- more, as many of these models
arise from problems involving partial differential equations and associated variational
inequalities or they contain distributed/stochastic variables and parameters, the practicioner is often met with an explosion in the number of decision variables upon discretiziation. With this minisymposium, we seek to achieve the following two scientific
goals: 1) Define and advance the current forefront of research in complementarity
problems and the optimization of complementarity-based systems, e.g., variational inequalities and equilibrium problems. 2) Identify analytical and numerical challenges
associated with the focus areas. In addition, we seek to bring together scientists working on both finite and infinite dimensional formulations of these problems so as better
ascertain the boundaries of possibility.
